Defender Talk about the Land Rover Defender within.
Looking for Vendor to Swap engine
Old Oct 2, 2012 | 02:42 PM
Jewbacca's Avatar
7th Gear
Default Looking for Vendor to Swap engine
I have a ex-military Defender with a 2.5na engine and am looking to install a 200tdi or 300tdi engine, so as to get a bit more "umph" from the vehicle.* I'd also be happy to install an Izuzu or that 5 cyclinder Mercedes engine.
Does anyone know of a provider who provides a complete "kit" so a skilled mechanic can drop one of these choices in the engine bay?
Thanks.
* I've seemingly failed at my attempts to located anyone who provides a bolt-on supercharger or turbo for these engines. There was an outfit called "Rimmer" in Colorado that did superchargers, but seemingly has disappeared.
Old Oct 2, 2012 | 10:06 PM
What kind of mileage do you see out of the 2.5NA Diesel
Old Oct 3, 2012 | 10:30 AM
Jewbacca's Avatar
7th Gear
I've only had it a little while, but it's the high 20s or very low 30s, and that's using farm diesel which tends to be on the crappy side.
Old Oct 5, 2012 | 02:36 PM
Thanks for the info
Old Oct 5, 2012 | 02:49 PM
jafir's Avatar
There were some 2.5 turbos from the factory, but everything I've read says to stay away from them, that they have lots of problems with cracked blocks or something. I'd think if you added the turbo to the NA, you might have the same problem.
Jonathan Bingham
Apr 9, 2014 11:31 AM
FierceSpeed
Apr 6, 2011 11:06 AM
robsondesign
Nov 11, 2010 03:53 AM
DiscoWest
Mar 15, 2010 11:24 AM
