Defender Talk about the Land Rover Defender within.
Need help identifying and replacing hose
Old May 7, 2024 | 08:54 PM
1997Defender90's Avatar
3rd Gear
Default Need help identifying and replacing hose
My radiator fan wouldn't turn on and I had an overheat in my 1997 Defender 90 2.0MPI Petrol.... and that overheat caused a crack in a small coolant hose which leaked quite a bit under pressure.
I've disconnected the fan temp sensor and then it'll turn on, so I assume I need a new sensor which is on the way soon.
But now I need to fix the hose as well. It's a small coolant hose that I just can't seem to identify in any diagrams or replacements as it's more difficult to find stuff on the 2.0MPI. Is there a replacement hose for this? or at least a kit I can pull from? Or maybe a universal hose I can cut to fit?
I've attached pictures of which hose it is, a small connector hose going to the top rail area. Drivers side of motor. It's not one of the large radiator hoses, it's the short piece, smaller/narrow hose.
Any help you can provide in a part number or replacement, or maybe something universal would be great. Really appreciate it!
Old May 9, 2024 | 05:15 AM
The Deputy's Avatar
Looks like regular heater hose, probably 5/8. Any parts store would have this.
Old May 10, 2024 | 08:10 AM
3rd Gear
Thank you so much! That's what I was hoping for, was just going to order a few different general hoses and cut to fit if needed, was just hoping it wasn't some funky width specific to LR.
Thanks again!
Old May 12, 2024 | 10:27 PM
3rd Gear
FYI - $16 5/8 hose from Advanced Auto with just cutting length a tad worked great. And unplugging the fan thermostat allows the fan to run so temp gauge stayed at half or a little less for quite some time during test drive. No longer leaking. Now just waiting on fan thermostat and hopefully that totally solves my overheating issues.
Thanks!
Invictus
Mar 14, 2022 08:26 AM
Emperor_MA
Jun 18, 2013 07:55 PM
discoguy96
Jun 11, 2012 01:25 PM
01disco2
Sep 10, 2010 02:31 PM
