Defender Talk about the Land Rover Defender within.
No heat
Old Jan 8, 2018 | 07:35 AM
lndrover@carolina.rr.com's Avatar
Default No heat
I have recently purchases a 1991 defender 90. I have no heat. Does this thing have heat a fan ect. Any help would be greatly apprcted. I really know nothing about this defender.
Thank you very much .
Joe
Old Jan 13, 2018 | 01:31 PM
Jack Kliever's Avatar
FYI the heat in these things is not great even when it works. In a '91 you probably have the old lucas glass fuses. That is most likely your problem. The fuse panel should be in the center under the dash, cover comes off with two *****. Often the fuse holders and connections get a little corroded, just fiddling with them can fix it. If a fuse is blown you need the lucas glass fuses, they are slightly different size than the standard american.
Old Jan 13, 2018 | 10:33 PM
What he said on checking fuses first.
The heat at best is terrible, good news is you live in NC so it should be good enough. Now the winters I drove it during the polar vortex in Chicago not so much.
Old Jan 13, 2018 | 10:37 PM
Robert Booth's Avatar
Mine throws out tons of heat and it’s s 109, so older than your 91 90/110.
Is your blower motor working?
Old Jan 13, 2018 | 10:44 PM
Mine is but the heat sucks for cold enviroments
jmason
Nov 17, 2013 06:39 AM
Evian
May 3, 2008 05:10 PM
fjfarias
Dec 12, 2005 05:43 PM
asmcmillin
Oct 30, 2005 12:23 AM
asmcmillin
Jan 23, 2005 01:18 AM
