Defender Talk about the Land Rover Defender within.
Oil on wiring loom.........
Old Mar 24, 2014 | 01:23 PM
lost in france's Avatar
Default Oil on wiring loom.........
I have a 2000 TD5 and have a problem with oil coming down the wiring loom from the injectors into the ECU box (I think?) This is causing strange things to happen with the motor....cutting out with the gearbox warning ligh on seem to be the worse !!!
Any help anyone ??
Many thanks..
Lost in France......
Old Apr 1, 2014 | 09:35 AM
jafir's Avatar
Pretty common. You'll have to replace the loom usually.
Fuel Injector Wiring Loom Td5 (OEM Leoni) AMR6103G Island 4x4 - Specialists in Land Rover and Range Rover Parts and accessories for all models. UK and worldwide mail order.
You'll also probably have to clean the oil out of all of the connectors.
See here for more info: http://www.aulro.com/afvb/technical-...l-ecu-box.html
redrover75
Jun 23, 2015 11:24 AM
chavhater
Sep 25, 2013 11:33 AM
sheenalandi
Audio/Visual Electronics
Feb 9, 2007 04:23 PM
shagybruce
Feb 8, 2007 02:52 PM
