Defender Talk about the Land Rover Defender within.
Rear Brakes won't release, suggestions?
Old Apr 22, 2018 | 06:09 PM
Submariner's Avatar
Default Rear Brakes won't release, suggestions?
88 defender 110, rear end is locked up.
This is what I have done so far.
Put her on jack stands, got the wheels off. on the left side I removed the screw to remove the hub, back off the cam shoe tensioner, took the BFH and tapped the drum to get it to release. got the drum off and cleaned things up. This is where the fun begins, the bolt for the forward cam tensioner on the left side spun freely, did not rotate the cam. Aft worked fine. Got things back together on the left side. Did pretty much the same on the right side but it was the back cam tensioner Bolt that spun with out moving the cam. Got the right side back together. the wheels turned free with a little drag on the drums.
Went to the cab and applied the brakes several time and that locked the brakes up again. I cannot get the wheels to turn at all.
Does this thing have a hydraulic lock on the brake system somewhere that I don't know about?
One more question, how do you get the brakes shoes off and back on with the spring set up? I done a lot of brake jobs on american cars and trucks. this is new to me. Thanks
Old May 2, 2018 | 03:32 PM
DavC's Avatar
I don't have rear drums so cannot help. Try Defendersource they will definitely know.
ljdiscovery
May 24, 2020 01:32 PM
bikingteacher
Jun 19, 2015 04:23 PM
Draayer
Jul 9, 2012 11:18 AM
FightOnUSC79
Nov 26, 2010 09:43 AM
aweber7367
Nov 8, 2010 04:07 PM
