Defender Talk about the Land Rover Defender within.
Screeching noise
Old Dec 29, 2021 | 07:21 AM
The Deputy's Avatar
Not sure on thread size, just remove and match up with longer bolt at hardware store, try to get grade 8, but grade 5 would be fine. Just loosen alternator bolts, as if tightening, and remove bolt. Reassemble with longer lower bolt, tighten belt, tighten bolts and then add nut to exposed portion of longer bolt as added security. And like l say, add flat washer to adjustment bracket side of bolt...it will add surface tension to retainer/bolt.
dealbergaria11
Oct 26, 2019 11:19 AM
Ems
Aug 1, 2012 08:22 PM
girouardrover
Mar 5, 2012 10:59 PM
lee666
Oct 14, 2007 12:07 PM
pickps
May 14, 2007 12:42 PM
