Defender Talk about the Land Rover Defender within.
TD5 engine fault
Old Oct 11, 2007 | 10:53 PM
alwaldin's Avatar
Default TD5 engine fault
Hi i'm new to the forum great to see all the help thats out there.
I have a TD5 that came in from Japan damaged.We had to take the head off to repair the timing cover.We've put it back together & everything is great except that when it warms up(not too warm) & you hold the engine at about 1500 rpm it starts smoking & the engine looses rpm & smokes more. You can increase the rev's & it clears off but this is at about 3500 rpm, then if you drop it back slowly it starts "bogging down" & smoking again until it gets back to idle when it comes clean again. We had synthetic oil in it but have changed this back to a 14w40 grade oil.....!!!
Any ideas...???
Al
pgaukroger
Feb 29, 2016 05:56 AM
06Range
May 8, 2013 09:01 PM
jmason
Mar 12, 2013 08:08 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
