Defender Talk about the Land Rover Defender within.
TD5 Rorschach test!
Old Mar 10, 2026 | 04:23 PM
leebones's Avatar
Default TD5 Rorschach test!
Hi everyone. I am hoping to enroll those willing to assist me diagnosing a very slow oil leak from my 2004 Defender 130 TD5, by starting with a Rorschach test of sorts! It took about two months of sitting still to produce this much oil on the garage floor, so a little faster than the pitch drop experiment. Given the active membership and collective wisdom in this subreddit, I wouldn't be surprised if someone would be able to identify the source of the leak from the oil drip pattern alone! Photo below.
I have put more detailed photos in this album, with highlights I thought noteworthy.
Ultimately I am trying to figure out if this is something I can fix myself, or if its above my paygrade. The biggest DIY projects I have done so far include swapping out the clutch master cylinder, and a full stage 2 upgrade. Thats probably the maximum of my skillset at this stage!
Thanks in advance!
Old Mar 10, 2026 | 04:34 PM
leebones's Avatar
I cross-posted this to reddit and got a response in less than 5 min. The person bet their last £1 that the cause would be a bad rocker cover gasket. Thoughts?
Old Mar 24, 2026 | 09:26 AM
The Deputy's Avatar
My first guess would have been the valve cover gasket, also. Oil leaks can be a bugger to figure out. Looking for the highest signs of oil on the block, usually helps eliminate other areas.
Abandisco
Oct 10, 2024 12:29 PM
Crossy
Jul 27, 2024 12:33 AM
Sabbe
Oct 14, 2021 08:11 PM
Alandisco2
May 8, 2018 05:58 PM
dave0
Dec 18, 2012 08:28 AM
