Oil leak from turbo area.
Old Jul 26, 2024 | 05:13 AM
Crossy's Avatar
Default Oil leak from turbo area.
Hello guys I've researched countless forums with no clear answers so thought I would create a post to see if see if anyone has any advice.
I've had a replacement engine fitted to my Discovery 3 (TDV6) after 2 years of waiting (let's not get into that &#129324 anyway happy to get it home only to find after the first successful drive that was was an oil leak dripping from the front left control arm area. On further inspection it seems to be from the turbo area. Didn't seem to be a major leak but would certainly lt leave enough on the ground to make it noticeable. Was hoping it would be as simple as a lose feed pipe but no such luck. From what I can see it seems to be coming from the front of the turbo on the intercooler pipe.
took it for another drive as it really wasn't leaking enough to be concerned immediately. This time the oil pressure light came on when the oil got warm. The next day I thought I would change the oil just incase the wrong oil was put in. When I drained it I would estimate 4 litres drained. I don't belive the leak was bad enough to cause that much oil to disappear.
I have 2 real questions. I know i don't have any pictures to help with this right now but is there any known causes that would cuase a leak from the turbo area that would be common before I take the Turbo out and replace it also could the oul be leaking into the likes of the intercooler and some been stored there? Secondly the oil pressure might be unrelated but could there be a link there? My plan is to change the oil pump for my own peace of mind even tho I was told the engine had got a new pump 6 months before being swapped into my Disco.
I will try get pictures that might help with the
Old Jul 27, 2024 | 12:33 AM
loanrangie's Avatar
No diesels sold in North America so you are unlikely to get nuch assistance here, TDV6 takes 5.7ltrs of oil so you are down almost a 1/3, Its normal for there to be some oil pass thru the intercooler due to the emissions crap on it including the EGR's but should only de a dribble unless your turbo is worn.
If not changed to the later oil pump then it should be done before it lets go, you don't mention the year so anything pre 08 should be replaced but needs to be checked to confirm.
A couple of other places known for oi leaks are the oil cooler in the valley and camshaft seals, also valve covers.
LR2driver
LR2
Oct 27, 2022 01:01 PM
BowRat
May 18, 2018 05:25 PM
ESPN
May 3, 2012 07:42 PM
kfox77
Apr 25, 2009 01:29 PM
okdiscoguy
Jul 9, 2007 10:49 AM
