1993 Camel Trophy
Old May 21, 2014 | 09:19 PM
  #41
Roflcopter's Avatar
So, after a long battle today(basically.... wiring, wiring, wiring, plaques, and 2 h3 bulbs being dead) it is done! It looks more like a camel vehicle now! Please note the roof rack is bent a little, so the plaque is actually not slightly crooked.
Basically, there are two power wires that go to the roof rack lights(hella 1000's). One wire splits 2 ways for each driving light, and the other wire splits 2 ways for each fog. One set of lights were working and the other were not. After some investigation, I found my way to the fault. It was in a nest of custom wiring and factory harnesses. Basically, someone had modified it at some point in time after the race. Each set of lights have a relay and someone rigged up the switch only to one relay, instead of two. A splice here and there. Bam. Lights.
Old May 22, 2014 | 06:03 AM
  #42
97GreenMeanie's Avatar
Wow! Those lights and plaques make a huge difference!
Looks awesome!
What is next?
Old May 23, 2014 | 10:51 AM
  #43
EricTyrrell's Avatar
Need to rub some fine dirt on those shiny new lenses to match the patina.
Old May 23, 2014 | 12:47 PM
  #44
oilspotLR's Avatar
Wow they really beat the crap out of them, but I guess it wasn't there trucks so who cares, lets hit the side of a tree a little faster right?
Old May 23, 2014 | 03:23 PM
  #45
CUpgt's Avatar
Well this particular one came off a trailer at highway speeds...
Old May 25, 2014 | 11:19 PM
  #46
Roflcopter's Avatar
So a camel trophy owners club member sent me these photos. Thought I would share them! Verified my export plates to the camel trophy owners info about my disco!
Michael Hussey and Tim Hensley
Old May 29, 2014 | 11:45 PM
  #47
TOM R's Avatar
What are those big traction planks called?
Old May 29, 2014 | 11:58 PM
  #48
Roflcopter's Avatar
The sand ladders? Which are cut up aluminum or steel Marsden Matting, used by the military to make makeshift runways.
Old May 30, 2014 | 11:17 AM
  #49
Can you post some photos of the sand ladder mounts on the SD rack when you get a chance?
I have some Perforated steel planks that I cut down years ago to 12"x36" and would like to mount one on each side of my SD low profile rack without dropping a ton of cash.
Thanks!!
Old May 30, 2014 | 04:56 PM
  #50
CUpgt's Avatar
Camel trophy rack is not an SD at all. It mounts to the actual roof and I believe it is tied into the internal cage.
