1995 Range Rover Won't Start
New to the Land Rover world. I just recently purchased a 95 Range Rover and she wont start. Pretty sure shes a Disco 1. Got it in the garage today and checked over her a bit. Maybe someone here has ideas or suggestions
She has spark, has 120 psi compression in two of the cylinders (didnt check the others), has fuel at the fuel pressure check valve. Tried getting her to kick over with starting fluid and nothing at all.
She will spin over fine, but wont kick what so ever.
Spark plug wires were just changed before i got it, timing chain was done 20k miles ago. Timing seems right to me. Shes not showing any codes on the diagnostics display. Coil and secondary coil ohms out good. The Ignition Amplifier is next to the coil i believe and i havnt checked that, not sure what to look for.
She only has 110k on her and seems in good condition, so hoping i can get her going.
Tomorrow i figure ill throw a timing light on it, maybe thatll tell me if the amplifier is throwing off the spark timing
Geeze, I think you need a larger garage! How many projects can you fit in a two car garage? You need this; http://www.landroverresource.com/rave.zip
It's a Disco. Even if it was a 95 Rangie you'd still be in the right ball park with the Disco crowd.
Uh, I'd check the wires for correct cylinder positions. They can be one position off and it probably won't start you know. If anybody removed the dizzy it's probably a tooth or two off, second guess.
Static time the beast using the Rave - the link I posted for you. If the amp is next to the coil then it's already been remote mounted because they sit on the dizzy body and overheat. Hope they indexed the chain correctly.......that would be my third guess.
I'm outta guesses right now.
just the rover, sidekick and little tractor in there now. I see youre in lower michigan, im in the UP.
Ill double check the plug wires tomorrow, i believe they are right. The timing chain was done by my buddies dad at a shop, small world eh? Looking at the receipts showed me that. It ran for 20k miles, so i wouldnt think it would be mechanical timing. Moving the dizzy back and forth in its alotted adjustment changed nothing also.
Where ya at up in the UP. My family is originally from Red Jacket (Calumet) and moved to the Detroit area when the auto companies grew in the 20's.
I was working on a 95 for a customer and had the plug wires off to remove a head. When I put them back on it wouldn't start, one off from the diagram. Fixed it and it started right up. My sons Dodge did start when we had the wires off by one but it obviously ran like crap.
It's not, lol. Messed with her a bit this morning. Wire routing looks correct, the rotor is pointing at the #1 cylinder when she is set to 6 degrees BTDC on the compression stroke. Everything timing wise looks correct, but it cant be. I pulled the dizzy out and took her apart, set the gap in there and put her back in and set to where i believed she should of went. Tried to start it and nothing, turned the dizzy all the way CCW in its mount and it wouldnt start, but it would cough like it was firing on the way wrong stroke. So tomorrow i guess ill have another go with her.
