1996 Disco 1 Roto-flex is getting fired!
Old Oct 13, 2017 | 08:06 PM
disco-disco's Avatar
Default 1996 Disco 1 Roto-flex is getting fired!
I am ready to can that roto-flex, mine is all cracked and old. I was at my local salvage yard today and grabbed the rear shaft off of a 1997 (the single u-joint type) thinking it would bolt up (why wouldn't it? this is a perfect world....right?) anyway, I knew it was too good to be true.
If I take the part of the drive shaft that bolts on to the pinion at the rear diff, from the 1997, will it fit on my 1996? thus allowing me to bolt the new drive shaft on?
Old Oct 13, 2017 | 08:17 PM
XCELLER8's Avatar
yes you need the "flange" from the rear diff from the donor truck....all should work after that, but you might want to get a new seal for the diff, and check on the torque spec for the nut that holds the flange on....dont over-do it ......
Old Oct 13, 2017 | 08:18 PM
OverRover's Avatar
Yes, you need the 4 bolt flange(STC4858) . Have a look > https://discoweb.org/oldsite/
> Drive Shaft Conversion Kit - Product Instructions
Old Oct 13, 2017 | 08:24 PM
yeah my seal is leaking pretty badly. Thanks!
Old Oct 13, 2017 | 08:26 PM
I am trying NOT to spend a ton of cash, that is why I am wondering if the rear yoke from the 97 will fit my 96.
Old Oct 13, 2017 | 08:27 PM
OverRover's Avatar
It will fit, but you will need a flange spacer to make the '97 flange fit. This> http://www.roverparts.com/Parts/539745
IDK if this link > https://discoweb.org/oldsite/ is going direct to TECH. If it isn't CLICK "Tech" at the top, then on the left scroll down to "Rotoflex to U-joint conversion"
Old Oct 13, 2017 | 11:25 PM
It will fit, but you will need a flange spacer to make the '97 flange fit. This> Differential Spacer (Part # 539745 ) - Land Rover differential internal from Atlantic British
PERFECT! thanks
Old Feb 8, 2023 | 04:04 PM
resamae87's Avatar
Default 97 land Rover discovery driveshaft help
97 land Rover discovery driveshaft help I'm ony second driveshaft part and it's doing the same thing as my last driveshaft part and it's the flange differential part that keeps messing up and I don't know what to do with it and how to fix this problem please someone help me
Wtf
Doesn't make any sense why it keeps messing up
Old Feb 11, 2023 | 05:51 PM
Machinistbutler's Avatar
How could the flange be that worn and the washer look new. Makes no sense
I Brake For Cats
Sep 1, 2020 10:40 PM
Charlie_V
Aug 29, 2015 12:59 PM
Danny Lee 97 Disco
Jan 27, 2011 09:32 PM
khuds308
May 12, 2008 09:38 PM
sailorcolin
Apr 14, 2008 09:20 PM
