1996 Disco I cannot get shifter nob off!
Old May 7, 2015 | 08:18 PM
Jkvoelker's Avatar
Default 1996 Disco I cannot get shifter *** off!
Yes totally new to the Land Rover. Long but amazing story short the sun roof leaked and now there is water sitting under the PRND123 so I need to suck it out.
Everything is off except the *** on the shifter, there is no screw or anything like I have seen in some threads. It is a manual and it has the little button on the side to pull out of park. I turned it really hard and now it spins idk if it is threaded or I probably just broke it. I tried to tap it with a hammer, does the thing just not come off?
Old May 7, 2015 | 10:02 PM
abran's Avatar
Remove rounded rectangle center cap on top of **** with small pry tool.
Remove clip at top of pin, remove plastic rocker, spring, side button.
Unscrew large nut, it's barely tight, I just use the nose of some needle nose pliers to spin it off.
Move your face to the side and pull up with great force... Did you hit your chin? Told you to move your face!
Old May 10, 2015 | 12:01 PM
Best4x4's Avatar
Also if your D1 has the weird little square clip holding everything together under the trim bezel you can replace it with a small c-clip if you accidentally bend it beyond repair.
Old May 11, 2015 | 01:05 PM
Jkvoelker's Avatar
There is nothing on the **** except the button on the side.
Old May 11, 2015 | 02:42 PM
abran's Avatar
There is an insert at the top, trust me. Pry it out/off and all will be revealed. Or post a pic, maybe someone installed an aftermarket Hurst shifter!
Old May 11, 2015 | 03:12 PM
fishEH's Avatar
This dimpled piece pops up with a screwdriver or knife. All will be revealed then.
Old May 12, 2015 | 01:10 PM
abran's Avatar
^ I was too lazy to post a pic!
harryob
Jul 9, 2015 12:57 PM
Joshman
Sep 28, 2012 01:36 AM
tibyABv6
Feb 27, 2010 09:25 AM
tiredone
Mar 2, 2009 11:12 AM
la gale
Oct 7, 2006 05:49 PM
