1996 Land Rover runs great won't always start
Old Feb 19, 2013 | 12:58 PM
Florida Rover's Avatar
3rd Gear
Default 1996 Land Rover runs great won't always start
My 1996 Land Rover will not start after having a new starter and battery installed. It runs great just won't always start. It is at the dealership and even they can't seem to figure this out.
Old Feb 20, 2013 | 01:44 AM
Pretty basic - needs spark and fuel. If it was at home, check fuel pressure on injector rail passenger side "tire valve" fitting, 32-34 PSi when pump runs. Check for no spark by attaching a spare plug and lay on mainifold. No spark is most likely crank position sensor. They could also do a visual check for bent reluctor tabs, but that should have misfires.
LR dealer? And they can't figure out a D1?
Old Mar 2, 2013 | 06:58 PM
JPSpen's Avatar
No fuel and it's possible your problem could be the immobilizer.. The circuit board gets cold solder joints and then the fuel pump intermittantly won't run. Turn the key on and listen for the fuel pump to run...
Good Luck
John
Florida Rover
Feb 19, 2013 08:06 PM
jfall
Jan 23, 2013 07:03 PM
Lincoln Tarantino
Jan 15, 2012 06:45 PM
sheelhorse
Jun 16, 2009 04:37 PM
dcarsmith
Mar 8, 2007 10:16 PM
