1997 Disco 1 rear door lock
Rear Cargo Lock Issues
Thanks for all the replies...to date I have tried 4 different motor actuators. Thru trial and error what i have discovered is power is getting to the electric acuator but for some reason the lock pops up and pulls back down when utilizing the key in the drivers door. Also, when the door is open and you work the handle it pull the lock door as well. I'm at a lost. It's almost like no DC power is getting to the actuator on the reverse for unlock.
The previous owner did have an amp booster attached to the door panel and i discovered while replacing the rear light assembly there is a red/orange wire cut in the wiring harness and another red wire looped in, i assume was for the amp. I 'm wondering if the red/orange wire has something to due with the DC power to the lock actuator? Since there is power to the actuator and the piston moves when activating the drivers door I'm unsure on the situation with this wire and have not stripped and tied back in due to risk of blowing fuses.
Any and all suggestions would be appreciated. Almost ready to surrender on this one and stay with the secondary key for getting into door.
Check this out!!
There is a little spring in the lock mechanism that goes bad.
Our Discovery I had the same problem.
I took the latch out and ordered a set of springs from this guy in the UK.
These are round springs which if broken, the latch will be inoperative.
They are HARD to remove and get in.
Want to kill of 4 hours..?
Well, here you go
discovery lock springs | eBay
Well, here you go
ebay search land rover discovery door spring
fixed my rear door by replacing a colapsed spring and i had the exact same issue. you may see a dangleing spring on the outside of the lock mech or no spring at all (missing) The springs are $4 each. the job wasnt too hard. a door pannel remover, some colored sharpies, large and regular head phillips drivers. pay mind to the linkage installation.
good luck
please report back with what you find
good luck
bcolins
11-08-2011 06:15 PM
