1997 Discovery I PO300
Old Feb 6, 2007 | 09:04 PM
felipenaves's Avatar
Default 1997 Discovery I PO300
Hi I own a 1997 Discovery it has 106.000 miles and the Check engine turn on, I testedand i have P0300 Random Multiple cylinder Misfire detected.They tell me that is the cataliyst, right now the car shakesmore and i think some cilinder are not working,
what is the problem, and what i shuold do please give some advise.
THXS
Old Feb 6, 2007 | 09:59 PM
Default RE: 1997 Discovery I PO300
A 0300 code is not your cats. What have you done over the last year or so as far as a tune up, how old are your plugs and wires, do you run high octane gas, have you decarboned your engine?
Mike
Old Feb 7, 2007 | 04:13 PM
I Just boughted this car and I think they havent done a tune up or change plugs, wires or decarbon the engine. How much do you think they are going to charge for all these and how long is going to take for this work. Im taking the car to www.britishcarservice.net here en Los Angeles CA.
Thanks for the quick response, I apreciate.
Felipe
Old Feb 7, 2007 | 09:15 PM
Why don't you do the work your self, it is easy, cheap and it will give you an opprotunityt to get better acquainted with your truck.
By the way, they will probably charge you around $600 plus and you can do it for around $200 in parts.
Be glad to walk you thru it.
By the way, your truck is way past do for a major service, no time like the present to find out what makes your truck tick.
Mike
Old Feb 13, 2007 | 05:01 PM
Default RE: 1997 Discovery I PO300 Problem Resolve
Thanks for the tips, the people from www.britishcarservice.net change me the plugs and wires and now my Disco run great. and was not that expensive like I thought.
Old Nov 11, 2011 | 04:25 PM
Perpetua1997's Avatar
Hi there! I own a 97 Discovery with 173,000 miles. I've owned her for 2 years now and never had a tune up. Any work that I have needed done has been minor and my brother has been able to do it. He checked her out and said he isn't going to attempt to do the tune up, because it's very different than what he is use to seeing. I know that I need to get this tune up done. I live in Salt Lake, Utah....Can anyone refer a service center other than Land Rover, or any pointers I can pass along to my brother?
Old Nov 11, 2011 | 05:00 PM
Download the factory service manual below, called the RAVE, it has step by step info. Change plugs and wires, use cheap $2 plugs.
martin12
Dec 14, 2014 08:21 PM
adamhannah
Aug 1, 2011 01:41 PM
wsroufe
Nov 7, 2010 08:09 PM
jumper95604
Oct 22, 2010 11:03 PM
Potomac Paddler
Oct 17, 2004 04:42 PM
