1997 Discovery won't go into gear
#21
I will say almost 100% sure your tranny is shot. You can try dropping the pan and changing the filter to see if you get some life back.
He mentioned surging, it didn't just stop. If it was a broken shaft, it would be bang and no movement. If it was the t-case, it wouldn't be a clunk, it would be a loud slam and a hard jerk. Almost like hitting a car.
If your problem before involved surging and the RPM's going higher, that was your sign your tranny was going out.
Most likely you ran a tranny low on fluid that didn't have good fluid to start with. Check the color. Should be pink, odds are it is dark brown, maybe with shavings in it.
#22
on
When he descibed his wife having a little trouble for several miles and it dying when she was almost home, that was a pretty good indication that she wiped out the tranny, he should have mentioned that first.
That what happens you have trouble for several miles and just keep driving hoping to just make it home, you destroy stuff.
capthook
09-22-2014 11:05 AM
