1997 land rover won't start
Old Oct 7, 2015 | 06:01 PM
Smitty's Avatar
Default 1997 land rover won't start
My 97discovery land rover won't turn over runs great park it when was raining and went to start it nothing but all lights work but no power to crank motor clicking sound glovebox need to jump from starter or what need back on road have 3 little kids please help
Old Oct 7, 2015 | 06:50 PM
Tracker1996's Avatar
I would start with checking fuses, then lightly tap on starter while having someone turn it over and if neither worked I would suspect crank sensor. Not to hard on the starter though you can damage it (as if you were cracking a pecan with a hammer). If it happens to be the starter you will want to get one soon...it may work again but, it's on it's way out.
Old Oct 8, 2015 | 11:10 AM
expeditionnw's Avatar
A crank sensor will NOT keep the starter from cranking. it will keep engine from firing. it controls fuel pump and ignition power.
I would bet its a security system issue.
Old Oct 8, 2015 | 11:36 AM
Detoured Discovey's Avatar
I agree with the security suggestion, mines done this......sometimes I remove the key and start over..........fires right up......other times it's left me sitting.......Love to bypass that security system!!
Old Oct 10, 2015 | 10:04 AM
Mark G's Avatar
What are the steps to overcome the security system problem?
Old Oct 10, 2015 | 12:00 PM
ihscouts's Avatar
Jumper two pins.
Old Oct 10, 2015 | 12:52 PM
jimvw57's Avatar
Could be a dead battery, easy to check, and you don't need to crawl under the truck. try using another vehicle to jump start it, if that doesn't work, then move to other checks. Make sure ground is clean and has a good connection. Try a jumper cable between engine block and body. Been there...
Old Oct 13, 2015 | 04:20 PM
geek_IM's Avatar
Originally Posted by ihscouts
Jumper two pins.
Hey Brother, you can't say that without letting inquiring minds who want to know which two pins.
Old Oct 13, 2015 | 05:24 PM
ihscouts's Avatar
Long time no see brother geek_IM. This was stolen from the "Tech Section". Thought it might get asked about sooner but I guess everybody's out Christmas shopping...... https://landroverforums.com/forum/di...sco-tip-55071/
laselvasurf
Jul 25, 2017 10:15 PM
kleener
Jul 12, 2013 08:06 AM
Mart 678
Dec 3, 2012 01:56 PM
Valkirai15
Sep 9, 2008 09:24 AM
jonman
Sep 1, 2007 04:01 PM
