2 issues pisssssing me off
Old May 12, 2011 | 06:09 PM
AKdisco's Avatar
Default 2 issues pisssssing me off
1. I want to install an aftermarket CD player but I pulled the factory one out and it has 3 harnesses that clip into the radio, and it has one huge wire for the SUB and one huge wire for the AMP. On my aftermarket CD player it does not have a place to plug in these 2 huge wire's. Do I need a special adapter harness? what did you guys do with these 2 wires?.
2. The trailer plug on the rear hitch is a weird one!. I went to a trailer specific store to find an adapter so I can haul my dirtbike trailer and the guy said that it was a specialty adapter OR re-wire the wiring to a domestic common 7" round plug. Should I order it or just pull the wires and install a common plug?.
Old May 12, 2011 | 06:13 PM
adigerol77's Avatar
Hey AK, here's an adapter from Crutchfield, this may solve your radio issue. Also I know in the RAVE they go into specific detail on wiring the trailer harness. Hope that helps.
PAC SOEM-4 Universal 4-channel line output converter at Crutchfield.com
Old May 12, 2011 | 08:44 PM
Danny Lee 97 Disco's Avatar
Trevor at RovahFarms has the trailer fix adapter really cheap. Look at the post I just did on the Electrical Parts.
I would bypass the Rover Radio Wiring completely. That's what I intend to do.
Old May 12, 2011 | 08:45 PM
adigerol77's Avatar
You beat me to it DL, I was just on Trevors site and saw the adapter. $6.99 can't go wrong.
Old May 12, 2011 | 08:58 PM
joefresso's Avatar
i too was wondering about the AUX and SUB cables. I'm thinking these are antennas and you only need one. I know there is an adapter for the antenna since most of the receivers take different antenna connection. i'm also doing this and made the mistake of getting a receiver with only 1 power amp (2 plugs)...need one with 2 power amp connections (4 plugs) for the adapter to work. check out metra audio for another adapter; this is where i got mine...now just waiting to get a new receiver in the mail with the correct amp hookups.
Old May 13, 2011 | 06:42 AM
turf63's Avatar
Yeah. I don't really see the point of keeping the amp in the loop since you're replacing the head unit with a powered one. Take the extra hour, run the new wire to the speakers and never think about that amp again. That's what I'll do when I stop fixing broken stuff.
Old May 13, 2011 | 08:28 AM
I was told the early disco amp is junk anyway. I will eventually put something in mine.
Old May 13, 2011 | 09:03 AM
WaltNYC's Avatar
This might help. Rather than running new wires to speakers and tearing up the interior of the truck, it might be better to understand the output side of the amp and simply use the wires already in place to the speakers.
Here is a diagram of the rear of the head unit......
The wire with 13 pins hanging off the back goes to the CD player. The block-ish adapter with 26 pins carries the inputs from the instrument cluster and the outputs to the amps (front and rear). The third connection is the antenna.
A helpful website....
http://carstereohelp.net/wireharness_LandRover2.htm
And a diagram of the output side of the stock amp in a 1997 Discovery I...
Hope that helps.
Old May 13, 2011 | 09:15 AM
kenk's Avatar
I bought/use the adapter from rovahfarm. The diagram of what terminals to put which wires to did not work for me. I had to test each terminal with a multi-meter while running tail,turn,etc. to figure which wires went where.
But,that's pretty minor, quick, and works great now.
Old May 13, 2011 | 09:18 AM
kenk's Avatar
If you do just re-wire it, all you'll have to do is locate the wire loom comming out the floor(underside of car) in the rear going to the trailer plug. Inside that wire loom is only 4 wires. Figure which wire does which light, splice a 4-way flat in accordingly.
I almost did this until I found the adapter so cheap at rovahfarm.
Rangebmw04
Jun 5, 2021 06:17 PM
LeeH0615
Mar 5, 2012 02:27 PM
thehun
Dec 27, 2010 03:41 PM
Spencerfitch
Dec 16, 2010 09:34 AM
andylad75
Sep 27, 2009 03:39 PM
