2 Q's Red or green coolant, which side is bank 1
Old Nov 30, 2011 | 03:28 PM
Discolife's Avatar
Default 2 Q's Red or green coolant, which side is bank 1
Buying a o2 sensor tonight and was reading about other guys overheating and read where somebody said Green coolant only. Mine has red and it never get above 192 but will stay around 180 average
Ultra gauge says bank one sensor 1
Old Nov 30, 2011 | 03:37 PM
Bank 1 is the drivers side. At your trucks mileage why are you replacing just one 02?
Not sure who coolant is Red, you should be running green or yellow, like Peak.
Old Nov 30, 2011 | 03:39 PM
Discolife's Avatar
Looks like dexcool,
bank one is drivers side eh? sensor one is closest to engine?
Old Nov 30, 2011 | 03:40 PM
Would stay away from Dexcool (orange) - turns into sludge. green or yellow good.
Old Nov 30, 2011 | 03:53 PM
psykokid's Avatar
Coming from VW/Audi's I've always had great success with the purple VW G12+ coolant. Comes in either 1.5 litre or 1 gallon concentrated bottle. Aluminum safe as well as phosphate and silica free.. Just dont mistake it for grape drink...
Attached Thumbnails 2 Q's Red or green coolant, which side is bank 1-grapedrink.jpg
Old Nov 30, 2011 | 08:47 PM
DI's came with standard green coolant, changed every 30k or 36months, whichever is sooner per the owners manual.
Old Nov 30, 2011 | 08:51 PM
Discolife's Avatar
what the dif? and do you guys use distilled?
Old Nov 30, 2011 | 08:54 PM
I buy it 50/50 premixed, its idiot proof, just pour it in and go, plus you get the full warranty from the coolant company.
Old Nov 30, 2011 | 08:55 PM
Discolife's Avatar
I do use water wetter or purple ICE any of you guys use that stuff?
Old Nov 30, 2011 | 09:02 PM
Nope. I do not believe in snake oil's, if you need to add a additive to your motor oil, power steering, transmission, coolant etc. then you either have a problem that needs to be fixed or you need to use a different fluid.
Engines are designed to run at a certain temp, what is the point in trying to lower the temp as much as possible?
How much does this crap lower the temp buy?
If you want a colder running engine then just put in a colder t-stat.
It did not come from the factory with extra crap in the radiator, or the engine oil or the transmission, so why add it now?
I just dont get it.
Each to their own.
