300tdi boost pin on an auto
Old Sep 17, 2021 | 11:43 AM
Russ6334's Avatar
7th Gear
Default 300tdi boost pin on an auto
Hi all
i can’t find any where info about fitting a boost pin to a 300tdi auto, or don’t know if the auto makes a difference but I very clearly do not have the fuel pump that’s on every YouTube boost pin fitting video????
I have some for of electronic box?
do I even have the same type fuel pump to fit the boost pin?
Old Sep 17, 2021 | 08:45 PM
disco96sd's Avatar
wow a diesel - cool we never got them here in the usa
Old Mar 21, 2022 | 12:08 PM
HowsThat's Avatar
Did you ever get around to figuring this out? Noticed mine was different before ordering one
Old Mar 30, 2022 | 02:18 PM
discomeans's Avatar
6th Gear
300Tdi auto D1 owner here. Probably one of a handful in the states as mine is an import from the UK which is kinda rare compared to Defenders. I don't have a ton of hands-on experience with these so you might be better off going to a UK or Australian-focused forum.
As I understand it, 300Tdis with autos came with Electronic Diesel Control (EDC). I believe that's what we're seeing here. Mine actually doesn't have that.
It's possible to convert from electronic to mechanical, but if you're not into that, you might look at a tuning kit like this instead: https://www.lrparts.net/as-tu02-300t...low-meter.html
BigDanSRQ
Apr 5, 2024 08:00 PM
sidescrollin
Dec 16, 2021 05:15 PM
greisinb
Feb 13, 2021 02:21 PM
tbessrn@gmail.com
May 9, 2017 06:49 PM
kenk
Jun 25, 2010 11:54 PM
