Can you use a D2 transfer box in a D1?
Old May 27, 2018 | 09:58 AM
Dog3leggeddog's Avatar
4th Gear
Default Can you use a D2 transfer box in a D1?
I recently purchased a 96' D1 manual truck that had a cooked transfer box. The seller gave me a good D2 box to be used in place of the rather toasted unit. I understand that they are basically the same units and side by side they have differences in sensor location, but the same accept for the speedo pickup. The plan was to replace the front output housing from the D1 to the D2 so that I could use my old selector, but the rear out put housing is a little bit speculative. Has anyone done this and is it as simple as swapping the front and rear housings out? I would rather not take apart a good transfer case to find out whether this will work or not if someone already has the knowledge. Thank you in advance.
Scott Weiland
Jul 11, 2013 10:05 AM
calebbo
Oct 12, 2011 09:54 PM
Hurricane Moon
Aug 15, 2010 06:09 PM
95LRD1
Oct 19, 2009 04:55 PM
ant996
Defender
Sep 14, 2006 05:03 AM
