4.6 upgrade?
Old Nov 24, 2013 | 11:15 PM
abran's Avatar
Default 4.6 upgrade?
I have a chance to pick up a 4.6 motor from a D2 to upgrade my D1 4.0.
The guy is offer the heads and the short block(with pistons, rods, crank, bearings, etc.) for $375. Im worried that the block and pistons are damaged.
He sent me the attached photos, any one have any thoughts? Should I be worried about the discolored area? He says its not a problem and shows the picture of the head with the spot of discoloration that matches the spot on the block.
Should I buy it?
Thanks
Attached Thumbnails 4.6 upgrade?-block-1.jpg   4.6 upgrade?-head-1.jpg   4.6 upgrade?-block-2.jpg   4.6 upgrade?-block-3.jpg
Old Nov 24, 2013 | 11:30 PM
jafir's Avatar
Later rover v8 blocks suck.
I'd buy it and put the crank, rods, pistons, etc in your 4.0 block.
Old Nov 24, 2013 | 11:31 PM
CUpgt's Avatar
You will have to convert it to a Gems motor to use it. IIRC the 97-99 P38 have Gems 4.6. Much easier swap
Old Nov 25, 2013 | 07:14 AM
drowssap's Avatar
the price is right, my question would be why did he go to the bother of pulling it apart and cleaning it up and did not use it.
Old Nov 25, 2013 | 10:37 AM
abran's Avatar
That's what I'm worried about. He said he got a good deal on a complete motor and ended up keeping the extra bits for back ups as it was cheaper not to replace the gaskets, head bolts, etc.
Old Nov 25, 2013 | 10:38 AM
abran's Avatar
Does anyone see any problems in the photo? Should that dis colored mark worry me?
Old Nov 25, 2013 | 06:10 PM
jastutte's Avatar
do what jafir said. the 4.6 blocks are time bombs.
Old Nov 25, 2013 | 09:57 PM
abran's Avatar
Sounds good. Weren't the 4.0 blocks and 4.6 made in the same factory? Is the problem that the tooling was so old by the 4.6 production that the blocks are no good?
A rover mechanic told he he sells his slipped liner blocks to these guys in the mid west that top hat the sleeves and ceramic coat the cooling cavities. Has anyone heard about the ceramic coating on the coolant cavities? What is the advantage?
Thanks.
Old Nov 26, 2013 | 08:23 AM
jafir's Avatar
All made in the same factory. Technically all of the 4.0 and 4.6 blocks are the same. There is some evidence that the 4.6 blocks in earlier years passed quality control better and that's why they were picked for 4.6 use. But all 03-04 in the US and Canada got a 4.6, so I doubt they could have been as picky in those years. The best engine block would probably be a 1996 or 1997, the first years for the 4.0/4.6. If I needed an engine for a d2 I'd look for a GEMS 4.6 range rover engine, and swap the stuff needed to make it a Bosch engine.
Old Nov 26, 2013 | 08:32 AM
drowssap's Avatar
Has anyone heard about the ceramic coating on the cavities? What is the advantage?
go to great plans rovers
bmwrovers
Sep 23, 2018 06:25 PM
Vazquezt
Jul 19, 2008 12:44 AM
Leo
Tires
Oct 9, 2006 06:25 PM
LR3invancouver
Apr 14, 2005 07:25 PM
jvanbelkum
Nov 4, 2004 05:00 PM
