94 Disco Code 45 thrown
Old Mar 23, 2011 | 01:48 PM
Cosmic88's Avatar
Originally Posted by losinov
Yeah new plugs, wires, cap and rotor. My MAF did have that metal screen in it but it shriveled up when it came in contact with some brake parts cleaner, a light mist of it actually. i was worried that screen had something to do with sensing other than just a block for foreign debris...
....Thanks for all your thoughts guys, but still unclear on where I should start checking?
Should I pull the plugs and make sure they are all in good shape? Check the injectors?
I will try swapping plugs and seeing if I get a code 44, reset the computer and drive like that for a bit to see if it triggers it again if not I'll put the original o2 back on the passenger side and see what happens, then I'll think about replacing them.
here's the deal... 44 and 45 are mostly triggered by over-rich conditions as sensed by the corresponding O2.
That could be a lot of things. For instance, an old sensor takes longer to "detect" the exhaust gas makeup because the ceramic coating over the Titanium Dioxide sensing element is, for lack of a better term, saturated with crap., which means the info sent to the ECM is technically speaking, inaccurate in relation to the current state of the mix. This is why they should be changed out around 80k to 100k miles.
Also sensor plug connector pins get corroded, oil fouling of the wires and or plug/wire/sensor... basically anything that throws the electrical signal to the ECM out of the "normal" range it is programmed to find acceptable. The ECM will then alter the air:fuel mix through timing, injector pulse width...etc. All of this stuff is related to the same symptom, over-rich mixture. A dirty MAF can cause this over rich mix too.
Start with the most basic things first. Spark. Are all wires making perfect contact at both ends? Are they routed correctly per the diagrams available? Believe it or not that last step is very important.
By the way, did you use brake cleaner to clean the MAF? I hope not...
Old Mar 23, 2011 | 02:04 PM
losinov's Avatar
Originally Posted by ColoDisco
Funny. I just did my head gaskets and had a similar fault if not the exact same fault. Cleared the faults per Cosmo, have not seen the fault since. I do still have a bit of a stumble every now and then at idle when taking off. I suspect a spark plug wire as I caught one grounding on the engine puller bracket by the power steering pump.
Is there a performance plug wire that is heavily insulated to stop this from happening?
Glad to hear it went well Colo, how do you clear the faults? Just remove the negative lead on the battery?
I replaced the stock silicone wires with 7mm Magnacore wires and they seem very sturdy. People recommend the 8mm but after speaking to a magnecore tech he suggested fitting would be cramped and difficult with the 8mm shielding. I will check to make sure they are not in contact with anything and grounding by accident. Talked to my tech up here and he said a bad injector might throw me for a loop with the O2 sensor codes.
Old Mar 23, 2011 | 02:28 PM
calebbo's Avatar
I had a code 44 last week. I took off the battery lead and it came back after a few days. So I checked my spark plug wires, pretty much just pushed down harder..idk if that helped, and jiggled the MAF..same as before. Then I went for a car wash, and sprayed underneath. Haven't seen the CEL for about 3 days.
Old Mar 23, 2011 | 02:41 PM
ColoDisco's Avatar
There is a better way that tweak pointed out to me in my Head Gasket thread here:
https://landroverforums.com/forum/di...e2/#post233309
Old Mar 23, 2011 | 06:14 PM
Danny Lee 97 Disco's Avatar
When you do replace them,I would go ahead and replace both betting that they are the originals unless otherwise known. Also they say only the fronts affect the performance, the rears are to tell you you cat is bad. But do eliminate the simple things first of course.
Old Mar 23, 2011 | 06:19 PM
Cosmic88's Avatar
Default 95
no rears on a 95.
Old Mar 24, 2011 | 07:55 PM
losinov's Avatar
So after pouring in the B&G44K I ran the tank through to almost empty and it seems that the rough idle is pretty much gone (knock on wood aka my head) I cleared the code following Cosmic's procedure and it worked, reader showed 02 code afterward but it went away after i started the car a 2nd time (02 code is power to the ecu) So we'll just wait and see if the CEL comes back... hopefully it doesn't though.
hatt53
Mar 27, 2013 05:16 PM
indasevens
Aug 20, 2012 11:39 AM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
Fireman
Oct 17, 2010 06:59 AM
