94 Disco, will not start
Well, we are almost there. everything is moving in order except now it wont start based on a perceived fuel delivery issue, spark tested, checked fuel in rail and pressure good. injectors are not working now. did i trip a fuse because of the battery being disconnected?
btw..i did check all of the engine compartment fuses they were all good as far as the ignition, fuel, etc. Not sure if there is something in the interior fuses i should check...researching rave manual now...
I also have a 94 and had a similar issue. If you trip the alarm the engine will turn over but not start. You will not get power to the fuel pump or coil. I don't have a remote so I had to disconnect the battery to reset it. In the tech section there is a write up about bypassing the alarm just in case. Hope this helps.
Evan5291
Jul 26, 2011 06:06 AM
bmoore0211
Mar 26, 2007 08:03 PM
