94 Disco, will not start
Old Nov 15, 2012 | 06:20 PM
  #21
JPSpen's Avatar
Sounds like you're on the right path finally..
Take that starter apart, Clean it up and get it working again..
Or just swap it for a new one..
John
Old Nov 16, 2012 | 06:23 PM
  #22
Viper61's Avatar
Default almost there......
Well, we are almost there. everything is moving in order except now it wont start based on a perceived fuel delivery issue, spark tested, checked fuel in rail and pressure good. injectors are not working now. did i trip a fuse because of the battery being disconnected?
Old Nov 16, 2012 | 06:49 PM
  #23
Viper61's Avatar
btw..i did check all of the engine compartment fuses they were all good as far as the ignition, fuel, etc. Not sure if there is something in the interior fuses i should check...researching rave manual now...
Old Jan 2, 2017 | 01:36 PM
  #24
RogueRoverOne's Avatar
Helpful post. Do you know where the starter relay is on the passenger side? I have a '96 disco as well.
Old Jan 3, 2017 | 09:21 AM
  #25
frankh's Avatar
I also have a 94 and had a similar issue. If you trip the alarm the engine will turn over but not start. You will not get power to the fuel pump or coil. I don't have a remote so I had to disconnect the battery to reset it. In the tech section there is a write up about bypassing the alarm just in case. Hope this helps.
Old Jan 5, 2017 | 12:18 PM
  #26
My mechanic friend disconnected the security relay on the passenger side and re-set the computer. I'm running w/o security, but I'm running.
Dryflyrod
Apr 23, 2014 06:02 PM
Evan5291
Jul 26, 2011 06:06 AM
armyeng
Mar 8, 2011 05:58 PM
pop1171
Dec 30, 2007 09:06 PM
bmoore0211
Mar 26, 2007 08:03 PM
