94 Disco won't start. Feel like I've tried everything.
Old Nov 11, 2013 | 03:08 PM
wabuson's Avatar
Default 94 Disco won't start. Feel like I've tried everything.
Car went out in the drive thru, possibly overheated, not 100% on that. Anyway I replaced the spark plugs and it started, drove but felt like it was misfiring. Went to check the wires and now it wont start. Replaced the wires, a bunch were corroded), distributor cap, rotor, i even put in a new air filter, checked the fuel rail (good pressure), fuel pump and filter. Coolant level, which was low. Still nothing. It was combusting in a cylinder or two for a little while and now nothing. Any help would be appreciated before I take it in.
Old Nov 11, 2013 | 10:34 PM
Check for spark.
The ignition control module could be bad.
Old Nov 18, 2013 | 08:12 AM
jbunner's Avatar
My rover sat for 2 months after doing tune-up and replacing fuel pump. I checked everything. Changed out coil, checked timing, etc. to no avail. Started over and found the rotor I got from Autozone was bad. Got cap and rotor from AB and it started right up.
Old Nov 18, 2013 | 08:05 PM
So with the bad rotor you saw that you had no spark? Using one of the spare plugs or just an old one you had not thrown away yet?
Old Nov 19, 2013 | 09:21 AM
jbunner's Avatar
There should be very little resistance at rotor. I took coil wire out and started car and listened. Then I used a spare spark plug. Then I removed distributor cover, disconnected coil wire and held it above rotor and turned car over and it sparked. I also got plug wires from autozone that were not good. I would recheck to make sure plug wires on right cylinders. Seems you have to order most parts for these.
Old Nov 19, 2013 | 01:36 PM
pathas's Avatar
what happened? did you have spark?
Old Nov 25, 2013 | 08:56 AM
jbunner's Avatar
It sparked holding the coil wire just above the rotor--bad rotor. Use insulated pliers.
srockrae
Jun 29, 2014 07:42 PM
Jono1387
Jun 11, 2014 12:38 PM
honda50r
Aug 16, 2011 04:44 AM
javoli002
Mar 29, 2009 10:56 PM
tomfraser
Mar 1, 2009 12:09 AM
