94 Discovery with warm start issue
Old Apr 25, 2011 | 02:16 AM
dunc's Avatar
5th Gear
Default warm start issues
i have noticed that i have a leaking fuel injector wich may be the problem but i wont be able to tell untill i get in there to fix it.
Old Apr 25, 2011 | 09:49 AM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Engine fuel temperature sensor (EFT Sensor),Engine coolant temperature sensor (ECT Sensor), Intake air temperature sensor (IAT Sensor) All can create this problem.
Old Apr 25, 2011 | 12:34 PM
Cosmic88's Avatar
Default Oh so close...
Almost had some good info there lrd2.... Fts is only used by the ecm on startup sequence and there is NO iats on the 14cux trucks like rrc, early series one discos and defenders
As you read and study more about the various model years you'll find that there are numerous differences.
Old Apr 25, 2011 | 01:13 PM
Arm and hammer's Avatar
When engine is cold your timing chain is tight , as engine warms up your timing chain stretch , it will not affect engine running but it will your hot engine start ups.Change your timing chain.Or drive as is.
Old Jun 23, 2011 | 07:16 PM
robertnsmith's Avatar
Default Reporting Back
Just thought I'd report back on my warm start issues. I had checked many of the usual things (ECT, IAT, etc.) and finally found my fuel pressure was low (~20psi). After a new fuel filter and fuel pump (I swapped in the Airtex E3270 for $80) and everything is good now. I think the pump was towards the end of it's useful life (and the fuel filter wasn't flowing as well as it should, which probably wasn't helping things either), and when warm, it just wasn't pushing enough pressure.
Running strong now... 224,xxx miles and counting (always on 87 octane... mentioned that just for funsies for all the guys that claim 87 is the devil for these).
Bob
atikovi
Mar 27, 2016 09:05 PM
doublebutta
Jan 11, 2011 10:42 AM
Darover
Aug 28, 2007 03:01 PM
mattrickman
Aug 3, 2007 01:22 PM
riemer
Jan 27, 2007 12:42 PM
