Sponsored by: CARiD
My warm Discovery won't start!!!
Old Dec 29, 2008 | 04:13 PM
doublebutta's Avatar
Default My warm Discovery won't start!!!
Hey everyone, Happy New Year! My baby is having a problem. She is a '96 Discovery and she won't run when hot. She will crank and fire momentarily but then dies. After several attempts, if I give it lots of gas, it will stay running but idle rough for 30 seconds, then run fine. And after cooling down, she has no problems. She doesn't have any signs of overheating, no engine lights on, no codes showing on my computer, and no other problems at all. My mechanic says "I dunno" and wants to just start replacing parts.I say I'd at least like a clue before forking over lots of dough! If anyone has any clue, I would appreciate the assistance. Happy Holidays!
Old Dec 29, 2008 | 05:58 PM
Default RE: My warm Discovery won't start!!!
When did you last replace the fuel filter?? How about the fuel pump relay, ever replace it?
Old Dec 29, 2008 | 10:44 PM
RoverPatrol's Avatar
3rd Gear
Sounds like a dirty fuel filter to me! Replace it and let us know how it turns out!
Old Dec 30, 2008 | 06:19 AM
rinmud's Avatar
Relay good possibility pull it out (yellow) and look for brown areas near the contacts. fuel filter????? now I have put a bunch of pumps in. Get it to do it and have someone with a pocket screw driver to push in th schrader valve on th fuel rail. The fuel filter will worsen after the car starts and progressively get worse as you drive ( fuel passing through trapping particles against the element) Now the relay will have trouble dropping if the connection is bad especially hot. Pumps get lazy hot too also the viton seat , if failed, in the neck of the pump ( check valve) allows the fuel rail presure to release and will cause a hot start issue. scott
Old Jan 6, 2011 | 11:02 PM
Spencerfitch's Avatar
wish the op posted his solution
Old Jan 7, 2011 | 05:57 AM
Someone PM him and ask him the outcome.
Old Jan 8, 2011 | 09:16 AM
Jull's Avatar
I'd like to know I have the same problem, it would be a no brainer if the tune-up wasn't done but it is. So I'm kind of running out of options.
Old Jan 11, 2011 | 10:42 AM
Jull's Avatar
The issue cleared itself. I'll check the truck out later this week.
Caleb.hunter
Aug 31, 2015 06:11 PM
dunc
Jun 23, 2011 07:16 PM
Darover
Aug 28, 2007 03:01 PM
mattrickman
Aug 3, 2007 01:22 PM
Tallguy
Jun 4, 2007 02:59 PM
