95 Disco 3.9 just stops about 20 minutes in
Old Jul 16, 2012 | 07:00 PM
waymore's Avatar
Default 95 Disco 3.9 just stops about 20 minutes in
Interesting issue here....
My 95 Discovery stalls after about 20 minutes of running and won't restart for at least 30-45 minutes, just cranks and cranks and cranks.
Fuel is present at the rail, although I do not know at what pressure, only that it squirts out when depressed.
Spark is present as I pulled a spark plug wire and held it against the manifold and saw spark.
Air would be the other necessity here, but I can not imagine that the air is any more restricted at minute 20 than it is at minute 5.
I was getting a code 48 stepper motor code on the OBD-1 display. I replaced the stepper motor and the issue is still present.
Any thoughts or ideas? Anyway to check fuel pressure without a fancy gauge?
All your help is appreciated.
Thanks
Old Jul 16, 2012 | 07:15 PM
tire pressure gauge will do, just throw it away once it has fuel in it.
Old Jul 16, 2012 | 08:20 PM
Bkreutz's Avatar
You may have a fuel pump (or relay) that's heating up with use, then quitting until it cools down. Checking the fuel pressure should confirm this. Low fuel pressure will cause the engine to quit running instantly (unlike a carburetor that will sputter and die). You want over 33 psi at the fuel rail.
forking
May 9, 2011 07:15 PM
JLEONE
Oct 30, 2008 08:49 AM
Chrisinhouston
Feb 7, 2008 07:51 AM
Rovercountry
Mar 22, 2006 03:38 PM
