95 Disco resetting reading SRS(airbag codes)
Old Jun 13, 2020 | 07:55 PM
FatMcNasty's Avatar
Default 95 Disco resetting reading SRS(airbag codes)
Hey all, It finally time for me to give back to the Land Rover forum help world.
Ive been fighting with a SRS light on the dash for a number of years and FINALLY got around to fixing it. And Im going to pass this on to all the poor souls that are stuck with a pre ODBII system.
Tools needed. Hawkeye Total reader, and BA5077 adapter for Airbags. Your thinking WTF Fat! I cant plug this in to my system I don't have a ODBII port!
Well we are going to make ONE! So grab a ODBII plug with pig tail from Amazon or some one else. Next find a plug that will work with the Airbag Diagnostic port. Its a square 4 pin plug look under your dash and it might still have one attached. If not get a scrap Ignition lock and pull it off of that one.
Pin out is as follows. pin 16 is 12V put a 2 amp fuse on it just incase.
Pin 4 goes to ground on the body.
Pin 14 goes to the upper left of the 4 pin to Yellow Pink
Pin 13 goes to the upper right pin Yellow Green
Pin 5 goes to lower left.
Like so.. Here is a shot of the whole adapter.
Once done making the cable, attach it in the rover, You can get power for it from the fuse box spade port 1, this gives power when the system is keyed on.
Attach the BA5077 adapter, which is just a pin shifter, that moves the reading pins from 15 and 7 to 13 and 14, which is the layout on the 96 forward DI's.
Attach the Hawkeye turn on ignition and read the DTC's then clear them. You will need to select the TRW MPS version. Mine was reporting a mem error and that what flagged it on for all these years.
So I hope this helps out another owner with the 95 system, I see there are a few of us out there with SRS lights on. And now finally a way to fix it with out having to go to the dealership to hook up the testbook to it.
Cheers
FatMcNasty
Old Jan 25, 2021 | 11:22 PM
britishtoys's Avatar
Hey Fat, thanks for the good info. I followed your instructions and finally got my SRS light off after 5 yrs. I paid a lot for that BA5077 adapter but now I'm thinking it was unnecessary. If the BA5077 is just a pin shifter( I took it apart and it's true, that's all it does) why can't you just do the same thing when you wire up the OBDII plug?
Old May 23, 2022 | 03:20 PM
Toran's Avatar
Hello Good People,
I have a Hawkeye scantool and was wondering if someone could please walk me through the exact steps for creating this substitute BA5077 dongle to turn off / reset my SRS light. Hopefully I can pick up the necessary parts on Amazon.
The SRS light came on when I replaced the battery a few months ago. Any additional insight would be much appreciated.
Thanks
Old May 23, 2022 | 07:43 PM
Toran's Avatar
Hello again,
Since I have an OBD2 port would I be looking at something like this to create a fake BA5077 dongle to work with my HawkEye?
Thanks
EricTyrrell
Oct 23, 2025 03:39 PM
weberic3
Feb 29, 2024 11:42 AM
austinlandroverbill
Jul 5, 2017 08:28 AM
Shark59
May 4, 2013 09:33 PM
Kyrowire
Aug 11, 2012 08:34 PM
