95 Disco Transfer Case
Old Nov 24, 2013 | 03:08 PM
rip5662's Avatar
Default 95 Disco Transfer Case
I'm new here and have recently purchased a 95 Disco. Replaced engine, transmission. I put everything bk together and the truck doesn't pull itself. The transfer case worked before I changed the engine and tranny. I removed the solenoid at the top that DiscoMike suggested. I have the console out and the front prop shaft removed. I can see the front trying to turn but it will not move the truck. Any insight would be very greatful. It doesn't feel as though the transfer case is going into gear all the way.
Old Nov 24, 2013 | 06:35 PM
nuclearw's Avatar
do you have the diff lock engaged? thats the only way it will move without both shafts
Old Nov 24, 2013 | 06:39 PM
rip5662's Avatar
It seems like it doesn't engage completely either way. Side to side is smooth but when it is in the back or forward position I can still move side to side.
Old Nov 24, 2013 | 07:17 PM
nuclearw's Avatar
its supposed to be like that, side to side is the "diff lock" that locks the front and rear shafts to the same rotation speed, front and back is the hi-lo gears
Old Nov 24, 2013 | 07:27 PM
rip5662's Avatar
It seems like it wants to move a little. Almost like a transmission when its low on fluid. I let it roll down the drive about 15' then it would pull slightly. It took high rpm's and about 10 mins to get back up the drive.
Old Nov 24, 2013 | 07:28 PM
rip5662's Avatar
Is there possibly something on the transmission that allows pressure to make the truck go? I'm at a loss.
texmanmoore
May 5, 2008 07:52 PM
mrjcrew
Apr 24, 2008 06:45 PM
tonyp71
Jan 13, 2008 08:46 AM
95DiscoSE7bullitt
Aug 19, 2007 09:45 PM
m1943
Aug 6, 2007 05:56 PM
