95 disco transfer case mod.
  #21
Old 04-06-2019, 10:35 PM
shawnsutton's Avatar
Originally Posted by fishEH
Man you're something special.
ok ok ok,why don't you educate me,What is the definition of a lever?
  #22
Old 04-06-2019, 10:41 PM
fishEH's Avatar
  #23
Old 04-06-2019, 10:49 PM
OverRover's Avatar
Because you asked
shawnsutton (04-06-2019)
  #24
Old 04-06-2019, 10:57 PM
Exactly.
  #25
Old 04-06-2019, 10:59 PM
Friday Night Disco's Avatar
  #26
fishEH's Avatar
Exactly.
https://en.m.wikipedia.org/wiki/Linkage_(mechanical)
  #27
Old 04-07-2019, 04:45 PM
ihscouts's Avatar
  #28
Old 04-08-2019, 07:11 AM
WaltNYC's Avatar
Now I've seen it all. An owner of one of the most capable 4WD vehicles wants to dismember those capabilities because he did not perform proper maintenance (checking oil/fluid levels).
The new transfer case will still need to be filled with gear oil and so removing the linkages to the mechanisms and/or the lever on the center tunnel inside the truck will do nothing to prevent this from happening again.
There is no logic to this and performing this removal will only serve to reduce the scrap value of the truck when it ultimately bites the dust which, one might argue, is close to happening based on the maintenance record of this owner.
  #29
Old 04-09-2019, 01:35 AM
Fair enough,I just bought the land Rover about 3 months ago i drove it for about 50 miles and this happened.PREVENTATIVE MAINT. no I failed to check it when i bought it.Most likely was on its way out when i bought it.
The shifter for hi/lo lock open is broke.So its coming out no matter what.But hey thanks for all your helpful post's they were very helpful.NOT.
  #30
Old 04-09-2019, 07:23 AM
robertf's Avatar
I use my land rover on and off road,I have never shifted it into low or diff lock.
You should probably sell it
Quick Reply: 95 disco transfer case mod.
