95 disco window question
Old Aug 13, 2010 | 06:52 PM
kcirtap's Avatar
Default 95 disco window question
just bought a cheap 95 disco to use in rebuild of my other 95 disco. The windows will not roll up! check switches good! motors maybe? any way due it is a parts car can you manually roll these windows up. I am gonna tear down rover and then send shell to junk yard! i would like to keep parts car dry from rain during this process. HELP! Thanks
Old Aug 13, 2010 | 08:11 PM
Do the rear windows on the good Rover work?
If so just swap the window lift ecus for half a minute, roll up the windows on the donor and then swap them back.
The window lift ecu is behind the glove box, the solder joints crack and then the windows wont work.
Resolder the cracked joints and they will work again.
Its a 15 min repair.
Old Aug 14, 2010 | 03:41 AM
kcirtap's Avatar
Default what does 95 disco window ecm look like
trying to locate behind glove box the window ecu? what does it look like? thanks
Old Aug 14, 2010 | 12:09 PM
discomedic4's Avatar
It's a black plastic box. You will be looking at it from the end. it is about an inch wide and about 4 inches tall (I think). It is just a plastic box with a plastic end cap in it. You just pop that cap off and pull out the board.
Old Aug 14, 2010 | 07:15 PM
kcirtap's Avatar
Default 95 disco window problem
fuse #15 10 amp was bad! windows are working now! Thanks
Old Aug 14, 2010 | 08:06 PM
Dont you love it when its the easy stuff?
Old Jun 13, 2013 | 01:45 PM
Toyfare's Avatar
Default Driver's Rear Window (Beating a Dead Horse)
**edit**
Meant to make new post.
twoxred
Oct 4, 2021 07:07 AM
RedAustinIX
Aug 10, 2020 11:43 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
