95 Discovery won't start
Old Nov 30, 2010 | 08:38 PM
  #21
Originally Posted by 95rover
Hi
I went out and tighten the nut on top of the shift. It did not make any differance. the nut was totally off. Any other ideas.
Thank You
Did you put the nut back on and tighten it?
Have you read the part in the tech section about fixing a broken ignition switch?
Old Nov 30, 2010 | 08:39 PM
  #22
Originally Posted by Cosmic88
For some reason I am way too interested in where this thread is going...
~Lurking in the background, waiting for the next gem to appear...
You need a hobby.
Old Nov 30, 2010 | 09:22 PM
  #23
Cosmic88's Avatar
RIGHT! What do you think THIS is?
Sometimes Dweb and Pirate can be truly entertaining... albeit a bit too harsh at times but this could have been a good one over there. ya know what I mean...
Old Nov 30, 2010 | 09:31 PM
  #24
demonlarry's Avatar
I'm glued as well!
Old Nov 30, 2010 | 09:44 PM
  #25
Yes I do, yes I do.
I have never been on Pirate but I was on DWeb for a short time, I didnt like it, way to harsh for me, I'm sensitive.
Old Dec 1, 2010 | 11:49 AM
  #26
Danny Lee 97 Disco's Avatar
Is that 3.9 a Land Rover 3.9 by any chance?
What condition is it in? If you are going to put in a differenet engine, go thru it good before you install it, much easier to fix it out of the vehicle than have to go thru installing it twice.
Old Dec 1, 2010 | 12:31 PM
  #27
Chris-bob's Avatar
Download the RAVE and see if you missed anything(sounds like you did). Go through each step EXACTLY to be positive. Then report back what you found. If you say nothing, then you need to look again. You should never have a "BOOM" coming from the intake after a simple gasket change unless you missed something.
Old Dec 1, 2010 | 12:44 PM
  #28
Sounds like vapors plus ignition source, very strange occurrence indeed for an internal combustion engine.
Old Dec 1, 2010 | 12:51 PM
  #29
Chris-bob's Avatar
Yes, but it sounds like his is trying to be an external combustion engine...
Old Dec 1, 2010 | 12:54 PM
  #30
Maybe the block is cracked allowing vapors to escape and ignite externally .......................
