96 Disco
Well I got the drive shaft back in and bungee corded the hood down and took the 96 for a quick ride around the block. All kinds of power steering noise..........no fluid. That explains the mess on the under side. Add that to list to sort out. Overall she did pretty good. I will title and register her on Monday. Then I can degreaser her start on the 60K items.
I need to loose the bungees. The Rave doesn't seem to give any details on the hood latch mechanism. Any suggestions?
Thanks RS
Thanks RS
I put in hood pins a few months ago and I am really happy with them. I had one sticky cable and another cable break so I got tired of fixing them. I made some supports to add strength to the radiator support where I put the pins. I'll get some pics if anyone is interested.
They are really simple to install, just drill for the pins and install those. After that, make a mark on your hood where the pins are going to go through, I used some grease on the tip of the pins and then paint pen to make a mark. I measured about 10 times so I was 100% sure it was going to align before drilling into my hood. Last, adjust the pin height for a snug fit and you're done.
