96 Disco
Old Mar 5, 2011 | 05:23 PM
Rearden Steel's Avatar
Default 96 Disco
Well I got the drive shaft back in and bungee corded the hood down and took the 96 for a quick ride around the block. All kinds of power steering noise..........no fluid. That explains the mess on the under side. Add that to list to sort out. Overall she did pretty good. I will title and register her on Monday. Then I can degreaser her start on the 60K items.
I need to loose the bungees. The Rave doesn't seem to give any details on the hood latch mechanism. Any suggestions?
Thanks RS
Old Mar 5, 2011 | 08:27 PM
thehun's Avatar
Hood pins ....thats what I am doing
Old Mar 5, 2011 | 08:56 PM
XCELLER8's Avatar
I changed the hood release cable on mine a couple of years ago and what a PITA that was......it would actually be easier to work on the latch if the radiator was out.......
Old Mar 5, 2011 | 09:19 PM
groundandpound's Avatar
X2 - After reading the horror stories, i switched to pins about a year ago.
Love them.
Old Mar 5, 2011 | 10:55 PM
bmxermike's Avatar
Love them.
I put in hood pins a few months ago and I am really happy with them. I had one sticky cable and another cable break so I got tired of fixing them. I made some supports to add strength to the radiator support where I put the pins. I'll get some pics if anyone is interested.
Old Mar 5, 2011 | 11:04 PM
nahtanoj's Avatar
i wouldn't mind seeing some pics.
Old Mar 5, 2011 | 11:15 PM
That's an interesting idea.....
Pics would be great. Where did you get the pins? Did you have to fabricate anything? Or was it just bolt on and cut some holes?
Thanks
RS
Old Mar 5, 2011 | 11:19 PM
bmxermike's Avatar
I just cut some aluminum angle, drilled, and bolted it in place. It's nothing fancy but it keeps that support from twisting when putting pressure on the pins.
Old Mar 6, 2011 | 01:03 AM
thehun's Avatar
see..i want mine for to the outside..gives more support during highway speeds...that mounts looks great though
Old Mar 6, 2011 | 01:12 AM
bmxermike's Avatar
Thanks
RS
Pins from autozone for $9.99 came with everything needed, I added the brakets but they aren't necessary.
They are really simple to install, just drill for the pins and install those. After that, make a mark on your hood where the pins are going to go through, I used some grease on the tip of the pins and then paint pen to make a mark. I measured about 10 times so I was 100% sure it was going to align before drilling into my hood. Last, adjust the pin height for a snug fit and you're done.
