96 Disco - in need of some major help troubleshooting
Old Sep 8, 2011 | 01:10 PM
My bad - the air temp sensor will be telling the ECU some wild tale about how cold or hot it is, and screwing with the fuel air mixture. Swap with new or one from salvage or dismantler. It should show up as IAT (Intake Air Temp) on a data reading scanner, so you could see if values were anywhere reasonable. Auto parts store should connect scanner for free.
Old Sep 8, 2011 | 01:17 PM
Paul Grant's Avatar
That may be but I'm wondering if we don't have a vacuum issue coming from restricted flow through one of the cats perhaps causing the elevated reading on the IAT. It's been know to happen. Putting it all together could certainly cause the bad response of idle.
Old Sep 8, 2011 | 02:39 PM
ValveCoverGasket's Avatar
my guess is the two issues are unrelated...
Old Sep 8, 2011 | 03:00 PM
Just unplugged mine, the scanner thinks it is -40F when the sensor is unplugged (which would equal open, or broken wires). ECU would adjust mixture and other things accordingly. So a data reading scanner will tell you if sensor is bad. Does not make truck rev high at idle when unplugged.
Could extract IAT sensor and let it hang in the engine bay, like guys do that have those cone air filters. Then you could pour water on it or hair dryer it to see temp change.
Old Sep 9, 2011 | 02:22 PM
fuze-17's Avatar
4th Gear
Default [Solved] Fuel Pump was the problem
I replaced the fuel pump, the inlet strainer fuel pump was clogged and needed to be replaced. I had to replaced the Fuel pump as well.. 65 bucks for the motor at Autozone
Airtex fuel pump, #E3240, about $65,
Old Sep 9, 2011 | 02:24 PM
Paul Grant's Avatar
Are you still displaying any codes?
88Mwife
Aug 21, 2011 08:06 AM
Billabong
Jan 27, 2010 12:36 AM
jmrmode
May 9, 2008 11:27 PM
direwolf41
Freelander
Jan 15, 2007 11:17 PM
97DISCOIDAHO
Sep 8, 2006 11:56 PM
