96 disco sputter problem help
Old Dec 12, 2012 | 11:02 PM
Landrovers65's Avatar
5th Gear
Default 96 disco sputter problem help
i have a 96 auto that when driving losses power and the speedo doesnt work right also. its been sitting for 2.5yrs i just got out of prison and need it to run i believ it might be the speed sensor were are these and are they the same as a manual as this is my 1st auto i have a few 5spd part trucks around please help 3'' lift 255/85 if that will help
Old Dec 13, 2012 | 01:40 AM
ihscouts's Avatar
Mounted to transfer case output housing near tranny brake backplate on drivers side. Tight spot. One allen head bolt. If your other parts trucks have their transfer cases your back in business.
The 3" lift on 255's won't help me but it'll sure help you to get under the truck.
Old Dec 13, 2012 | 09:45 AM
The speed sensor is number one suspect, the ECU thinks you are driving faster than take off velocity. If you can't get it swapped, might try driving with it unplugged to see if the sputtering goes away.
Old Dec 13, 2012 | 08:20 PM
5th Gear
thanks i had a few cases laying around i never knew that was speed sensor i should have it together tommorrow its been a nightmare i forgot how much i loved british vehicals and there problems power steering whining bad gotta love lucas oil, again thanks for the help. I will be selling a few of the parts i have left nothing really aftermarket. 1 white 1 black 96 5 spd discos Se7 both are non running one has water problems 26,000mi and other bad tranny 135,000mi eight,five,nine 595 eight eight eight 2 my name is stewart central ky
b c
Mar 1, 2014 11:45 AM
jhill15
Mar 27, 2013 01:23 AM
steveo2000
Sep 9, 2011 09:32 PM
Luxor
Jun 26, 2007 02:37 AM
skhmfirst
Mar 4, 2006 03:47 PM
