'96 Discovery with alarm issues and won't start?
Old Nov 13, 2012 | 03:48 PM
KaymonM's Avatar
3rd Gear
Default '96 Discovery with alarm issues and won't start?
Today, my battery died but someone came to jump me off. But, in the midst of this, I locked my keys in my car... With no spare I had no other choice but to smash one of the little back triangle windows out...
Then the alarm went off, and wouldnt let me start my car...
This is the only car I have, I am a single mother with two jobs I dont know what to do... Help?
Old Nov 13, 2012 | 04:11 PM
KaymonM's Avatar
3rd Gear
It is a '96 Discovery 1. When I bought it about a month ago, it had two keys with it...
One for the doors and then one for the ignition. No remote, no nothing. To unlock the driver door, you have to hold the key in the unlock position and open the handle at the same time. Just figured that would help.
Old Nov 13, 2012 | 04:21 PM
KaymonM's Avatar
3rd Gear
Basically my question is, what do I need to do in order to get it functioning again?
Old Nov 13, 2012 | 05:26 PM
Michael M. Koch's Avatar
Try locking and unlocking the driver door three times. This is supposed to disable the alarm and the immobilizer.
Old Nov 15, 2012 | 09:42 AM
Higgs Boson's Avatar
Cycling the ignition on and off several times will usually work. Turn it to run, wait 30 seconds and repeat. Once the ECU and alarm recognize each other you should get the check engine light to illuminate with the key on. If you do not get the CE light with the key in the run position(bulb test) most likely you will not be getting this truck started. Avoid disconnecting the battery in an attempt to reset the system, the system is designed to return to the same state it was in when power was interrupted. You run the risk of it locking you out completely.
With the door key, make sure you turn it from the locked position all the way back to the unlocked position, and then to center.
cu42dk
Apr 4, 2014 06:36 PM
Sinner
Dec 3, 2013 10:41 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
dmatranga
Feb 5, 2013 12:27 AM
craig110
Jan 25, 2011 05:05 PM
