96 Discovery Problems
Old 04-03-2011, 05:48 PM
97rangeroverP38's Avatar
3rd Gear
Default 96 Discovery Problems
I just picked up a 96 Discovery and wanted to check my mechanics recommendation.
1996 Discovery
120,000
Issues:
Misfires at idle & when revving to about 2.5-3 RPMs
Smoke comes out of air vents & behind vehicle when I am accelerating
Leaking oil
Fault Codes:
P0300, P0306, P0304, P0303, P1316, P1314
Mechanics Recommendation:
Change valve covers
Change ignition cables & spark plugs
Also is there anything I should be aware of if I am to buy the parts for the above and have a friend work on with me (a mechanic that is not used to Land Rovers)?
Thanks
Old 04-03-2011, 05:55 PM
Dont change the valve covers, just tighten the bolts, 8mm 12 point socket.
They all work loose and leak, just tighten the ones you can reach and 95% of the time the leaks stop.
As for the plug wires, Magnecor or Kingsbourne are the recommended ones to use, 7mm came from the factory on the truck, I have 8mm on mine.
If you use cheap plug wires you will have problems.
As for spark plugs, just plain old cheap copper plugs will do.
Old 04-03-2011, 06:20 PM
3rd Gear
Is there any major difference between the 7mm, 8mm and 8.5mm as far as performance? Also, any specific place to purchase from online? apex performance in SC has them for $80 or so..
Old 04-03-2011, 06:52 PM
8.5mm wont fit in the wire looms, get the 8mm for $5 more.
I personally dont think there is any difference between 7mm and 8mm, I mean really? 1mm is small.
But I went with the 8mm anyway and I also ordered from Apex.
Plugs you can buy locally.
Old 04-03-2011, 08:00 PM
antichrist's Avatar
I bought my Magnecore's from Apex about 5 years ago or so. But I like the Kingsborne price better and I think they are just as good. So I've gone back to Kingsborne (I started using them on my Rovers 25 years ago or so).
Old 04-03-2011, 08:25 PM
I actually bought the ProLine Wires from Rovers North 2 years ago for 50 bucks.
They are larger, package says heavy duty. They work great.
Old 04-04-2011, 06:44 PM
3rd Gear
Thanks all for the advice. I talked to the guys @ Kingsborne and will give their wires a try. I'll follow all recommendations and post a response soon.
Old 04-04-2011, 11:11 PM
Soccer Dad's Avatar
If all high voltage wires (read: ignition wires) deteriorate with use, how come that the high tension (voltage) lead on the CRT (TV) flyby doesn't deteriorate? I think that HT leads are designed to fail.
I run Magnecor 8.5: drilled the wire holders to make them fit.
BUT! they still failed.
So, instead of replacing them, I slipped high voltage insulator tubing (silicone and glassfiber) over the HT wires... what a pain to do but worth it. Also put this tubing anywhere the HT wires were rubbing against , like the dipstick tube.
The total size of the Ht lead is now around 15mm, no more misfire problems, the plugs are always fresh and I can drench the engine and it won't flinch a bit.
The tubing is available at UAP/NAPA, you'll need two packs.
SD
Old 04-05-2011, 11:04 AM
Chris-bob's Avatar
SD
Do you have a part number for NAPA?
Frank4
03-21-2014 05:21 AM
jack112286
12-02-2006 11:49 AM
CMARCH702
09-21-2006 04:09 PM
Sean 1313
08-30-2005 10:17 PM
dma3
04-02-2005 02:55 AM
Quick Reply: 96 Discovery Problems
