96 discovery Transfer case shifter issue - Video included
Old Nov 8, 2018 | 05:14 PM
ihscouts's Avatar
My guess is there is something wrong with the stick (hehe). It is a plastic ball and socket type articulation with a spring for preload, really stupid overkill for what it does. It would take Superman to bend either linkage using that type of setup. You might also have a stuck High/Low selector on the transfer case from lack of much use being that your in B'ham. It pivots radially and is a wonder to loosen without removing the linkage through the floor opening for the shifter. I like my Heep more and more....... It took me seven years to finally break and fix my tc shifter, flopped around like a wet noodle. I removed all interlocks, park and tc wise while fixing the shifter, old solenoids like to poop their coils.
Old Nov 9, 2018 | 11:37 AM
whiskeynipple0088's Avatar
I forgot about the soleniod involved that can go bad and not allow you to go to Low - I have removed mine for this reason - just rtv'd the cover back on.
You can easily see it right on top of the case once you come in from the top.
Some people use sheet metal screw to replace the rivits of the boot.
Old Nov 10, 2018 | 02:50 PM
mware18's Avatar
Console out, auto shifter out of the way and looking down on transfer case. First thing I see is cable with eye ring on the end sitting on top of t case and not connected to anything. What is this and where does it connect? It is sitting on the top near a plate with 7 screws. six around the plate perimeter and one other.
Old Nov 10, 2018 | 03:23 PM
stillruns's Avatar
Got a photo you can post looking down?
Old Nov 10, 2018 | 04:49 PM
Icannap1's Avatar
Take a picture so we see what you are seeing. PO may have installed something different aftermarket or mickey mouse something.
Old Nov 10, 2018 | 04:55 PM
mware18's Avatar
I found where the cable attaches. Found a pic on google. Also, problem with CDL lever not moving from front to back solved by removing the solenoid.
I can move freely now between locked and unlocked, low and high. I do not get any lights on the dash when I moved to locked.
Thoughts?
Old Nov 10, 2018 | 05:07 PM
ihscouts's Avatar
Check dash bulb with another known good from dash and check the TC switch/connection.
Old Nov 10, 2018 | 06:00 PM
mware18's Avatar
Here is the cable that was not attached.
Old Nov 10, 2018 | 06:11 PM
mware18's Avatar
Where can I find the TC switch to check the switch? I removed the solenoid earlier. Is it the in front of the four bolt plate I removed for solenoid?
Old Nov 10, 2018 | 06:33 PM
ihscouts's Avatar
No, it's the one you have circled with a fake crayola......
