'96 Land Rover Discovery rear break bleed help
The rust must have distorted the size. I too had a little trouble. I used a socket and gently tapped it on to the bleed screw. After I was able to break it loose I switched to standard open ended wrench. Of course being very careful not to snap it off. The bleed screw that is. I can't remember what that other bolt it though.
Looks like you live in the Rust Belt. Where are you located.
sayeedA
03-06-2014 07:15 PM
lowerrb
06-14-2013 07:25 AM
MTristan
03-18-2011 09:40 PM
echoes_and_fractals
08-27-2006 11:11 AM
