'96 Land Rover Discovery rear break bleed help
Old Apr 27, 2013 | 07:09 PM
landrovernoob's Avatar
Default '96 Land Rover Discovery rear break bleed help
Having trouble bleeding the rear calipers. Are they like the front where you open close the bleeder nipple? Is there a desperate screw from the nipple?
I can't seem to find a way to get the 7/16 wrench on the bleeder nipple.
Old Apr 28, 2013 | 02:38 PM
Tony K's Avatar
On my 96 disco I usually just bleed the passenger side with a 10mm, open end wrench hope that helps!
Old Apr 28, 2013 | 03:14 PM
jafir's Avatar
Is the plastic/rubber cover still on the bleeder?
Old Apr 28, 2013 | 03:36 PM
Yeti's Avatar
Bled my 98' yesterday, mine was an 11mm, YMMV. I could not get a traditional flare nut wrench in there. I used a standard 11mm wrench, just be careful not to round the bleeder off.
Old Apr 28, 2013 | 05:55 PM
CUpgt's Avatar
Speed bleeders ftw. Best $25 I've spent in a while!
Old May 4, 2013 | 08:31 PM
Default Hi and thank you for all your help so far! Could you take a look at this?
Old May 4, 2013 | 08:41 PM
bcbp's Avatar
The rust must have distorted the size. I too had a little trouble. I used a socket and gently tapped it on to the bleed screw. After I was able to break it loose I switched to standard open ended wrench. Of course being very careful not to snap it off. The bleed screw that is. I can't remember what that other bolt it though.
Old May 5, 2013 | 08:52 AM
petedisco's Avatar
The other bolt is a plug for another line that is not used. Id replace the whole caliper looks like most of the metal on it is gone.
Old May 5, 2013 | 10:24 AM
fishEH's Avatar
This is sound advice. Use the smallest 6 point socket that will fit on it. You may have to tap it on a bit to get the rust off. Take it off with the socket. Replace with a new bleed screw. M1.0x10 I think.
Looks like you live in the Rust Belt. Where are you located.
MTristan
Mar 18, 2011 09:40 PM
JavaDiscoII
May 29, 2010 04:33 PM
echoes_and_fractals
Aug 27, 2006 11:11 AM
