96 wont turn over...
Old Dec 19, 2011 | 06:30 PM
Ok, if spark and fuel is getting to each cylinder there is no reason for it not to run other than no air.
Old Dec 19, 2011 | 06:42 PM
hh65flyer's Avatar
I've seen engines that wouldn't start because the timing was too far out of whack as a result of timing gear/chain jumped. I know this to be common in old Pontiac engines and had it happen to me. Had spark and fuel but would not fire.
Just a thought...not sure what the failure mode is on the LR engines regarding timing chain jump/stretch.
Old Dec 19, 2011 | 06:56 PM
That is a good point flyer.
Get ahold of a timing light and check the timing.
Does any one know what the timing is supposed to be?
Old Dec 19, 2011 | 07:54 PM
Danny Lee 97 Disco's Avatar
When they towed it, was it flat bedded or towed with one end on the ground?
Maybe the alarm system has struck?
Old Dec 19, 2011 | 08:34 PM
JumPeR04's Avatar
flat bed and i will get a timing light.i have to check the rave and see what it say
Old Dec 24, 2011 | 09:46 AM
JumPeR04's Avatar
It is alive and kicking... It was the factory alarm.... :d merry christmas....
Old Dec 24, 2011 | 09:50 AM
Glad you got it worked out.
What did you end up doing to fix it?
Old Dec 24, 2011 | 10:14 AM
JumPeR04's Avatar
reset the factory alarm by the key trick also i got 1316 code maybe where they put in 89 oct so i am going put some lucas in it...
SolbergFanBoi
Mar 5, 2012 07:05 PM
DiscoveryHouston
Nov 14, 2009 11:07 AM
cbritt
Oct 13, 2009 07:23 AM
cellman01
Jul 28, 2009 06:44 PM
tryinthis2
May 22, 2008 09:35 AM
