97 D1 fuel pump which one?
Old Jan 21, 2014 | 11:53 AM
Halftrack's Avatar
7th Gear
Default 97 D1 fuel pump which one?
Hello all,
Another new guy question about fuel pumps. I searched the threads and it appears that there are two different type of fuel pumps, an expensive one ($400 +) and a less expensive one ($75). Ours has two electrical plugs recessed into the top of the fuel pump with what appears to be a vacuum (?) connection. So I'm guessing that it is the AEP type. What is the best source for a replacement unit?
Our fuel pump operates, but the two metal fuel line connections extending out of the top are severely corroded. Most likely these metal connections will fail when I attempt to disconnect the fuel lines. I'm pulling the pump to investigate a nonoperational fuel gauge.
Thanks for any advice, KC
Old Jan 21, 2014 | 01:25 PM
abran's Avatar
"Electric Fuel Pump Assembly DELPHI WFX 1010120 with Level sending unit.
This fuel pump is compatible with Discovery Series 1 1997, 1998 and 1999 SD Sport 4.0L 3950CC V8 Gas OHV Naturally aspirated;
Evaporative type fuel deliver systems."
That's the one you need, expensive!
floundering
Jan 24, 2024 08:24 AM
landlover_1
Off Topic
16
Aug 14, 2014 01:04 PM
grandkodiak
Apr 19, 2014 11:01 PM
Jared9220
Jan 7, 2014 12:18 AM
JumPeR04
Apr 7, 2011 09:52 PM
