97 D1 Running rich, shifting late
Old Mar 10, 2013 | 07:00 PM
Plus944's Avatar
None of the auto parts places around me including autozone rented that type of scanner. Would a voltmeter tell me if it was malfunctioning? Also I scanned it again and got codes saying there was a short circuit in the oxygen sensors upstream and an open circuit downstream. Does that mean all the 02 sensors are bad or what?
Old Mar 10, 2013 | 08:18 PM
Yes you can check the temp sensor with a voltmeter.
If you have codes for the up stream O2's then you either need a tune up or new O2's.
Bad O2's can cause it to run rich, so can worn out spark plugs.
Worn out spark plugs can set off O2 codes.
Old Mar 10, 2013 | 08:28 PM
Plus944's Avatar
Might be worth trying different wires then. I'll check the sender tomorrow with my voltmeter. What should the resistance be?
Old Mar 10, 2013 | 08:57 PM
I have no idea what the resistance should be.
But I do know it will vary depending on temp.
Old Mar 11, 2013 | 05:57 PM
Plus944's Avatar
Ok, so I need to measure it when the car is running? Dumb question maybe but I'm no electrician.
Old Mar 11, 2013 | 07:59 PM
I can change a light bulb if I have help...so I cant help you on that.
Old Mar 12, 2013 | 08:37 PM
Plus944's Avatar
Ok the resistance with the car off was like 5.5k ohms with engine running 1.7k ohms. Now to find out what that means
Old Mar 13, 2013 | 04:13 PM
Plus944's Avatar
Forgot to mention that the muffler is completely missing. I've read in passing that can affect mixture. Could that be part of the problem?
RYAN3326
Feb 17, 2014 11:43 PM
kristoffersmith
Aug 13, 2013 04:40 AM
disco boy
Sep 18, 2006 10:30 AM
dmonares
Aug 27, 2006 01:47 PM
Tibbs
Oct 2, 2005 12:08 AM
