97 Disco Stalls
97 Disco, 130K,no mods. intermittently stalls typically on the freeway. Never when cold
Throws codes for:
cylinder misfire in 3 or 4.
P1316 excessive emissions fault
P0183 Fuel temp circuit A high
I have Replaced plugs, leads and coil pack.
The enine runs like: run! stall for three seconds then run! stall for three seconds. The engine runs very smoothly, has a nice idle and generally purrs except for this cutting out problem.
Where should I look next? Fuel related? Blocked cat?
I love this truck and any help would be much appreciated. I have all the factory workshop literature.
Thnks for your consideration.
Throws codes for:
This is a common DI problem.
Yes it will run but you will not know how fast you are going so use a GPS or application on smart phone that can tell you your speed.
