97 disco will shift to drive position but won't go
Old Mar 30, 2016 | 01:05 AM
Idioteque2's Avatar
Default 97 disco will shift to drive position but won't go
Hi all, thanks in advanced for the advice. I've got disco 1 that's doesn't want to go once I shift it to drive. It will go in reverse but that's it. I'll shift it into D but doesn't seem to engage. What are some of the quick and easy things to do before breaking open the transfer case (I assume)? I guess fluid changes to the transfer case and/or transmission to start? Or does this sound something more mechanical or broken? So far no weird grinding or clanking noises. Will engaging the CDL do more harm than good? Thanks.
Old Mar 30, 2016 | 06:01 AM
TOM R's Avatar
Did you check the trans fluid level?
Old Mar 30, 2016 | 10:48 AM
Idioteque2's Avatar
Level looks good, but doesnt look as clear as it could be. Doesn't hurt to change I guess.
Any other suggestions, anyone?
Old Mar 30, 2016 | 07:08 PM
ihscouts's Avatar
Might want to check the trans filter. Lotsa fun. Have you tried locking the transfer case?
Old Apr 3, 2016 | 08:15 PM
blackoval84's Avatar
Default same here !
I've got the same problem on my 97 D1 , I've replaced the trans filter and put two bottles of Lucas stop slip ....but it's to no avail . I've checked all the linkages .....every thing seems good there .
I'm currently an Automotive Tech. Student at a local CC , my instructors seem to think it is one of the forward drive gears inside the transmission have worn or gone out ....so it looks like both of us are facing a rebuild or a new/newer transmission.
Old Apr 3, 2016 | 09:56 PM
ihscouts's Avatar
Optimism in the face of defeat...... the ZF is a pretty tough transmission even when neglected. Used are not hard to source and inexpensive. Ashcroft Transmission offers rebuild kits as does fleabay. Couple of DIY rebuilds; DIY rebuild your 4HP24 thread
ZF 4HP22 step by step. | Classic Rover Forum
Old Apr 4, 2016 | 06:16 AM
TOM R's Avatar
Put in drive see if a d/s spins truck on ground, try diff lock
Old Apr 4, 2016 | 10:35 AM
Idioteque2's Avatar
Nooooo! Ha I was hoping to avoid that. So it's the transmission not a transfer case issue? I just drained all my fluids yesterday and will refill today. I did notice the transfer case was covered in oil and dirt so it's leaking, but looks like it's coming from the front portion not the plate. Also, when I drained it not much came out at all. I'm hoping I'll just have refill the fluids and drive off....but that sounds too easy.
I'll post my results and let you know. In the meantime, I'll start reading about transmission swaps.
sjewell
Sep 12, 2019 11:55 AM
importdave
Sep 25, 2014 10:18 PM
kleener
Jul 12, 2013 08:06 AM
Caz Brookes
Oct 30, 2012 06:16 PM
