98 D1 4 to 5 starts than out
Old Jan 6, 2011 | 01:17 PM
Mike_C's Avatar
what CCA should I get?
Old Jan 6, 2011 | 03:21 PM
Danny Lee 97 Disco's Avatar
PepBoys had the Bosch at a good price but the damn thing does not have a top handle on it like most do so it was difficult to lower in, I ended up using a luggage strap from an old travel bag to loop under it to aid in lowering in place and for future removal.
Old Jan 6, 2011 | 07:22 PM
Chris-bob's Avatar
Originally Posted by Disco Mike
First of all, should have installed an 800 CCA or above battery.
At this point your battery is dead, need to either charge or jump it and take the truck down to a local parts store where they can test the charging system for free. You have to be above 13.6 volts.
Let us know what you find.
Mike says 800cca. If you had problems with 700, and the battery isn't up to par, then go up to 800+ cca. But make sure you test your charging system. I think 700cca should work fine if your charging system is in top notch shape.
Old Jan 9, 2011 | 08:19 PM
Mike_C's Avatar
Went with the Duralast Gold for $99.00, man what a differance this battery cranks...(no pun intended) 800 CCA, 1000 Crank Amps, 8 year warranty.
How can you bet that!!
Old Jan 10, 2011 | 07:54 PM
tornado_735's Avatar
FWIW, I had an interstate sit dead and frozen in my garage all last winter. Once I got the truck up and running, I tossed it in, gave the truck a jump, drove it around for about 3 hours, and haven't had a single problem since.
Old Jan 11, 2011 | 01:02 PM
Often times, an intermittent start problem is usually associated with poor ground connections at the starter to frame connection as well as the battery ground connection to the frame. This can be resolved by doing new ground connections to the frame at both components.
My 97 had developed an intermittent start problem and I fixed it by abrading the frame down to bare metal with a deburring bit from my Dremel kit. I then drilled a pilot hole in this bare area and attached new ground lugs todirectly to the frame with a self-drilling body bolt. For the starter, I merely cut off the existing lug, stripped the existing cable and crimped on a new lug. For the battery, I bought a new cable from Pep Boys.
Yes a new battery will work fine for a while, but if the grounds are corroded, the problem will return. Tom offered new cables made from welding cable and high grade lugs at a very good price. Do a search and you will find all the details along with some pics I posted.
Ad!
Aug 18, 2021 07:30 AM
lordmorpheus
Feb 17, 2015 04:42 PM
PaimonH
Oct 15, 2008 05:54 PM
jim1372
Aug 15, 2007 09:20 PM
PK
Jul 8, 2006 10:16 AM
